Perform this procedure to view the UNI ports associated with particular remote IP multicast routes.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select SPBM Remote.
  3. Select the IpMcastRoutes tab.
  4. Select an entry.
  5. Select the UNI Ports button.
IpMcastRoutes-Uni Ports Field Descriptions
Use data in the following table to use the IpMcastRoutes-Uni Ports tab.
Name
Description
VsnIsid
Specifies the VSN I-SID. Layer 2 VSN and Layer 3 VSN each require a VSN I-SID.
Group
Specifies the group IP address for the IP Multicast over Fabric Connect route.
Source
Specifies the IP address where the IP Multicast over Fabric Connect route originates.
NickName
Specifies the nickname.
EgressVlan
Specifies the egress VLAN of the IP multicast route.
EgressActivePorts
Specifies the egress active ports.
